trailqueen
- Dec 30, 2006
- 118
- 0
I'm getting between 150-200 miles out of a spark plug - is that normal? (this is my first 2t)
I read the thread about why 2t's smoke and someone posted that too much gas in the cylinder will foul plugs. Isn't it the oil that fouls the plugs?
If it's too much gas that's causing the problem, can I change the mix from 50:1 to 40:1 without changing the jetting, or will that cause excessive smoke?
It's an 07 ktm 200 xc-w (great bike!). It's running on a 50:1 synthetic mix. The pilot jet was moved from 42 to 40 and the needle clip was moved up one position. Except for the plug issue, it runs great. Thanks. :cool:
