James51381
- Mar 17, 2002
- 30
- 0
i took it in to service, to see if it needed a new top end. the guy said that it had a really good compresion. he rode it around and said it isnt running half of what it should be. granted it has the stock jetting, but I really didnt notice much of a power difference. I did notice the 49 tooth rear sprocket difference. He also took of the timing cover and discovered a reall small leak, but said its not big deal yet. my power valve is working great, so he said the only thing left is the carb (stock mind you) so i was thinking to send it in to rb designs. could this fix my problem? i have no mid or upper power. after the first initial "punch" there is nothing. any suggestions? thanks
James
pro circuit pipe
v-force cage and valves
fmf arrestor
no air box lid
49 tooth rear sproket
James
pro circuit pipe
fmf arrestor
no air box lid
