I just spent a fortune having a new sleeve pressed in to my 2000 CR250 cylinder by a local professional boring shop. I gave them my new Wiseco piston to fit and whatnot as well....
I am a fairly good machanic in my opinion (although I don't work on many 2 stroke bikes).
I put everything together as per specs reading everything from the service manual to the wiseco installation instructions. I put the bike back together and it had no power at all... I finally found out (after a lot of googling) that I put the piston with the arrow pointing towards the intake side and not the exhaust side.
After pulling the cylindar back off the bike tonight I see the top ring has caught on the exhaust port and broke the top of the piston etc etc... All from being put in backwards.
I read over my manual AGAIN and the wiseco instuctions AGAIN and the Wiseco instructions say NOTHING about what direction the arrow should go. What I did see is the marking on the original honda piston went towards the intake so I assumed the same.
If I call Wiseco and explain that their instuctions say nothing about this and now I have a busted piston, a severly scored NEW sleeve will they even consider replacing the piston?
I am not about 450.00 in to this top end job and am ready to slit my wrists.
C
C
