I think the reeds are a decent idea. Check the reeds you have. If they are warped or damaged, go for it.
The 82 Yamaha's had stainless steel reeds. I imagine your bike does as well. If these broke it would be bad news. Maybe a replacemant due to time is the best way to look at it?
I put Boyesen reeds in my 86 RM250 a couple years ago, it was a big improvement. The 86 OEM reeds were a plastic material (nylon i think) and mine were wore out, had gaps of 2 to 3 millimeters between the reed and reed cage. The biggest improvement in my bike was at low RPM, with noticeably smoother idle, easier starting, and more low end. It's hard to say how much of this improvement was due to the Boyesen reeds compared to fresh stock reeds.
Stainless steel reeds last a long time, so if that's what yours are made of they might be OK. They will cause some damage if they break, though, like Rcannon said.
Whether or not it's worth it to put Boyesens in your 82 depends on what kind of shape its in and how long you plan to keep it. For example, if your top end is worn out, you are better off fixing that before spending money on reeds. If the bike's in good shape, then go for it! They will make your bike run better.
I put Boydsens 2 stage tourque (power??) reeds in my '79 YZ400 and was very impressed.
Smoothened out the power delivery, and made the bike much more "rideable".
Would highly recomend them.
