Well today I finally got time to tear into the top end of the KDX250. Nothing wrong, just it is time to do a top end. Compression was down to 140, limit is 220-145. Bike ran good, seemed a little flat up top. Tons of low end.
So get everything off. KIPS are not seized which is good, but the the amount of carbon on the KIPS and center exhaust valve was unreal! I could not believe the system still worked! I thought at first the center exhaust valve was toast cause it looked like a scratch about 1/4" deep in it. After about 4 hours of soaking in solvent, it is carbon build up! wow!
Anyone know how much the left and right KIPS valve go for at the dealer roughly? A few teeth are not looking good and the other one has some plating that is coming off the top shaft. Figure I should replace both while I am in there.
Anyhow, figured I have a B piston in the bike. Just waiting for some new tools I ordered to come in to measure what I need. Found out the cylinder is lightly ported. Opened up a bit and smoothed the corners mostly. I got a VforceII for the bike and then get the dents out of the pipe and I should really find some serious power in the motor!
