Duwvesmith
- Dec 16, 2001
- 22
- 0
I am trying to improve midrange power on my WR250f.
The problem: The engine stumbles and coughs.
When: At about 3000-4000 rpm when riding at a steady pace, roll the throttle back to wide open. The engine then stumbles and coughs and has very little power.
I have tried several things to improve this but have not found a solution yet.
I am running race gas.
I have cut the gray wire.
I have removed the throttle stop, the airbox snorkle and the exhaust insert.
I have raised the needle 1 notch (lowered the clip)
The above mods have made great improvements in low and high end power. One other thing I have tried is changing the timing of the exhaust cam back 1 tooth so the timing dots are level with the head (YZ spec). This improved the stumble but I was told to change it back by Thumper racing. Apparently the WR ignition is timed to match the original cam orientation. I did this and now the bike runs like **** again.
Should I go ahead and change the cam to YZ spec again, or is there another problem I have missed?
I need someone who has solved this problem to give me a hand. I would greatly appriciate it!
Matt
Matt
