murdermittens
9
hey guys im looking for some direction on my bike
recently over the past year ive had tons of problems with starting my bike
sometimes it takes forever and my legs almost so dead i cant even ride hard for about 20 minutes
usually i start with tipping the bike on its side letting some fuel leak out , full choke 3-4 decompression kicks then a regular kick in the past its done fine and started great lately no dice .
just this past thursday i rode for about 2 hours not only did it not start till about 10 -15 kicks it wouldnt run off of choke half choke only no choke = sputtering
then about 2 hours after i rode i tried to start it again after i washed it ( kicked it about 7 times and it was still not starting )
ive tried everything in the past new plugs air filter etc.
this weekend im going to do a new filter and try to fully clean my carb and start with a new plug im also thinking i might need to adjust the valves ( some help here would be great as well. i think a clymer manual is in my future )
help anyone ???? :bang: :bang:
XRpredator
AssClown SuperPowers
13,504
I'm betting on the valves
the manual will walk you through it easy peasy lemon squeezy
I agree with Pred. Check your valves. Also check your compression after you adjust your valves. You may have burnt valves or worn rings. A bike with low compression is very hard to start. You may also want to remove and clean your carburator. Especially the pilot circuit. Having to use the choke or partial choke would indicate a clogged pilot air circuit.
murdermittens
9
thanks for the reply
hopefully theres no worn rings this bikes only an 04 and its not raced trail ridden only
thanks for the help guys its much apreciated
murdermittens
9
bikes never been touched internally or externally next to oil changes and filter changes
if your speaking of the decompression system its activated by a lever on the bars ???
XRpredator
13,504
I believe he is talking about thus. I know the early 80's vintage XR500R had the auto-decomp (I learned a hard way), but I don't recall the XR400 having an auto-decomp system . . . but I'm getting old. I'll have to study this further.
whether it has that or not, the cable getting out of adjustment could cause the decomp to open the valves just a skosh, keeping you from building up the necessary compression for starting. Another thing to look at while you're adjusting your valves.
and trust me, valve adjustments on that RFVC head are pretty easy. If you get a manual (clymer or otherwise) it'll walk you through it and you'll wonder how come you didn't do it sooner, it's so easy.
