A friend of mine has an 87 XR250. He has heard mixed opinions about how much air pressure should be in the front forks. The local Honda shop said "not much", a fellow rider said 10-11psi, his dad says about 3 psi and he read some where that there should be ZERO psi. I fthere is supposed to be 0 psi, then why would they have the air valve at the top of the forks. The reason we think that somthing is wrong is because when you sit on the bike you lean forward...it feels as if you are going downhill on level ground. Is this normal??? :uh:
