K Dixon
Well I was finally convinced, installed the XR springs today. They were $52.95 each CDN vs $67.95 each for Kawasaki springs, that helped the decision. With a measured distance between the top of the installed spring and the bottom of the fork cap, installed on the extended rod, of 3mm, I ended up needing a piece PVC pipe exactly 10mm for a 10mm preload. ( 10mm pipe + 3mm of spacer guides ) Just lucky I guess. I now have an unloaded sag of 1.25" and a loaded sag of 2.5". I think this is in the right ballpark. Question is does anyone know the relationship between preload & sag ? i.e. how much would an increase of 2mm of preload on the springs lessen the unloaded sag ?
Fred T
5,272
Could you stick a few washers in it just to see as a temporary static sag adjustment check? (Don't ride it like that!)
BTW-your numbers look pretty good to me. 35-40 MM static sag right?
dmcc
64
Where can I find good info (instructions) on installing new springs, preload, oil level, etc? I feel fairly comfortable doing it, but forks are something I've just never been into before. Thanks!
canyncarvr
4,005
Do you want to lessen the sag, or just interested in the numbers? As you say and fred concurs...your numbers look pretty good now.
I'm curious how you like the springs....or not.
K Dixon
Have not tried the forks yet, still too much snow up here, I'll let you know when I get a chance to ride. I don't nessasarily want to change the sag, just wanted to know if anyone knew the relationship between preload and corresponding change in sag. Fred had a good point I could find out by trial and error, just easier if someone knew. BTW I have found that an 8ml increase in oil raises the level in the tubes by about 5mm. I went a low oil level for now (125mm 7wt ) and will add oil with a needle through the bleed screw if I notice harsh or frequent bottoming. Also thanks to Canyncarver for your posts about the springs, they helped in my decision to buy and install them. I'm sure they will be an improvement.
canyncarvr
4,005
Great! 8ml is good for 5mm? That's good to know. Yeah, it would be good to know the relationship to preload/sag you asked about. That would depend on how fat (or not) the rider was, though!
Uh....a ml is = to a cc, ain't it?
Don't say 'thanks' unless you like 'em. Otherwise it would be useless/erroneous lies. All lies!! ;)
Don't want that!!
Good Luck!
bmonnig
79
I've got a pair of '98 XR 400 springs (.38, I believe) that will be going in the front of my otherwise-bone-stock '00 KDX 200.
I've read mixed posts stating that correct springs will only make the valving issue worse.  I'm 185 lbs without gear.  I'm not afraid to add/remove shims from the valve stacks, but I don't want to spend the $$$ right now for a Race Tech Gold Valve.  Is there anything I can do with existing hardware to improve the action?
As always, any tips/advice will be greatly appreciated!
Moose95
328
Hey C.C., yes a ml = cc .  I've been curious about the XR 400 springs in the KDX.  Seems like there was a fellow (from down under) who swears by them.
BucKat
271
A little off topic but hey,,,,
K Dixon ...where in Ontario. I'm 1hr east of T.O.
Where do you ride??
Joe
K Dixon
Hi Joe, you must be close to me I'm in Belleville. I Have usually been riding with a group in the Ganaraska forest.
Clint Key
Where they stock XR springs?I just ordered a set of eibach .45kg series 990 fork springs from Factory Connections the other day.The 990 series fits XR250s and KDXs.Mine springs were about a little over a 1/8 shorter than the stockers (the stockers were 17 1/2 inchs long) so get all the right preload I added the 2 thick washers to make up for the length difference and then went to wal-mart and got a set of tow hinch spacers that were 1/2 long and the right diameter and put those in.They are alot stiffer than the stock .40kgs.
andrew
278
Clint, I got a set of Eibach's also, to suit XR400 (not XR250). They were a fair bit longer than the stock KDX spring, which is better because I have all the fork tube taken up with spring, not preload spacers. I think going with a spring that is shorter than stock is possibly the wrong way to go... that said, it's just my opinion, and if you're happy with the way they perform, that's all that matters.
Cheers,
Andrew
canyncarvr
4,005
You're thinking of Dazza.....I think. He tried a set and liked them. That was before he put an orange front end on his kdx.
Aftermarket springs for a honda are not the same as the springs from honda.
Yeah...I HAVE said that a few times. Call me 'canynclutter'.
....oh......yeah......that's already been done.....;)
