jmics19067
- Jan 22, 2002
- 2,097
- 0
can any one tell me the difference in engine components between 77-78 yz 400s and the 79 400?
everything appears to be similar in bore/stroke/ rod length ...external dimensions but yet the parts are different.crank pin different size ,crank webs and piston visually different with cutouts. Is the difference only in balancing on the components? My real question being can I stick a 78 yz 400 crank/rod/piston assembly inside a 79 case/cylinder?
