Just came to change piston on my 03 yz 125 and it is a right mess on the exhaust side. It has stock jetting run on good fuel with 150ml of oil to a gallon and i keep the filter and airbox as clean as can be. It has had about 20 hours use since the last piston change.
Last time there was a flat spot on the piston where the exhaust bridge is but i had it relieved. This time it is about 20mm across. I think i have caught it in time as the cylinder is not too bad but obviously want to try and stop it from happening again.
Any advice would be great.
Thanks Ian
Thanks Ian
