There is gas in the tank but is it getting to the carb? If it's getting to the carb is the carb dirty? Chances are you need to clean the carb to at least eliminate that issue. This means really cleaning it as it take it apart and use a good quality carb cleaner to get everything spotless. Check each of the jets by hold them to a light and make sure you can see light.
