NO HAND
1,198
No, but you can use the values in your owners manual and check with a ohm meter if the cdi is still within specs.
halfpint 1
ok got the cdi unit and now it gets fire but wont start was told to un hook the exaust and try and it cought on fire a little but didnt crank over please help if you know what the problem is
kingbrian
123
dont know who told you to try it without the exhaust but i think it would be pretty hard to get a good running bike to start without it (2 stroke). id go for the compression check and make sure the carb is in good working order, and dont forget a good plug
