Recently purchased bike. Clutch pulled a little stiff. Therefore I installed a new clutch kit with both plates and springs. Still rough to pull. Went to put on a new cable and think I found the issue but not sure what. The acuator arm under the cover that the cable hooks onto seems to be way out of adjustment. When i pull on the cable the arm starts to come up like it's supposed to, but doesn't start engageing or spreading the clutch plates on the other side until it's about 3/4 of the way up. So i'm only getting about the last quater pull if you know what I mean. Here is where I'm stuck. Does it sound like it could be the rod that goes through the case could be worn so much it's shortened or something. Never really dug any deeper into a clutch that's why i'm at a stand still. Thanks
