I'm hoping someone here might be able to give me some info about my bike, a 00 KX125 I bought used. I have to admit that this was my first dirtbike and my first 2-stroke bike I've ever had. There were things that of course popped up after I bought it that need fixing and I didn't know to look for. The first thing I need to get is a service manual, any ideas on what brand to get, is the factory one the best choice? where's the place to get it? The two local dealers I went to in CT didn't have a exhaust gasket, let alone a service manual. Does anyone know the best setup as far as carb settings and sparkplug, the bike has a Pro Circuit works pipe with a PC 304 silencer. The person before me had a BR8EVX plug in it, which is a hotter plug. It was black and oily when I took it out, I bought a BR9 which is stock for it. Should I put a 8 back in instead? I'm not looking for the fastest KX at all, I just want it to be set up right, and not end up damaging the motor. Any info on fork seal how to? One seal is leaking. OK, one last thing, this whole dismantling thing started because it leaked oil, so after cleaning it I discoverd what was a hole? on the bottom of the motor right at the seams of the case. The hole is right below on the cases where the lower front engine mount bolt goes thru, but only on one of the halfs. I poked some safty wire into it and it seemed to go in about a inch and a half? I could put it all together and just fill it with oil( whats the best oil to put in? 10W30?) and look to see if it's leaking from there, but I figured I'd ask here first. Please be gentle on the replies I know I sound clueless, but everyone here was where I'm at at some point too. Jason
