2002 YZ250 Oil Capacity only 300ml or 750ml?
Wpreston
I have a 2002 yz250 and when I change the oil I pull off filler cap and drain oil but no matter how hard I try I only get about 300ml out. What the heck? I can pull the weep bolt also. When I fill it up it only takes 300ml also till it comes out the weep hole. The case itself says 750ml will somebody with the same bike help me out, is that all the oil I will get out or is there a trick to it? Also is there a filter to change also or not I can't find one.
FruDaddy
2,854
Is the bike vertical and level on the stand when you change it? I actually lean mine to the side nearest the plug. Also, loosen the filler plug so air can come in from the top. Other than that, I don't know.
Wpreston
Bike is straight up and down on stand, and I have tipped it and the filler cap is off but still on 300ML out and in.
Apr 2, 2005
73
also it helps if the oil is a little warm before you drain it. Any signs of leaking? how does the oil look when it comes out?
if your still only getting 350ml's in you've got me, I'd pull your clutch cover and inspect.
Morvo
205
Just looks like it hasn't been filled up properly in the past, either that or your bike is burning up shed loads of oil. Just measure out 750ml, pour it in, have a good few rags around with your bike, then drop the oil to see how much is left.
VintageDirt
Baked Spud
3,043
Are you removing drain plugs from the frame and the case?
VintageDirt
Baked Spud
3,043
oops, guess I assume every one has a 4-stroke these days. <redface>
Rooster
Today's Tom Sawyer
3,300
Agreed on the incorrect reading from the "check level hole". I have a '00 YZ250, had the same confusion. Drain it good, and put the full 750ml in it.
Manuals are always good to have on hand :cool:
CHR!S
293
quote from my yz250 manual "start the bike and let it warm up for a few minutes. wait for five minute." perhaps the oil was not filled all the way last time?
