I have not reached the jetting yet. You should be able to richen or lean it, if the electrics are working properly. how it would run with it unplugged? I would get a carb without the power jet. Standard power jet is a 42, and unlike the leak jet, that it is made like, leaner is leaner. That power jet effects the widest range on the throttle, 1/4 to wfo. I do want to keep it and jet it. Vintage Bobplynn41 said:Hey Bob,
Can you give some more information on unplugging the power jet and rejetting on the '97-98? Does the power jet lean the mid or upper range out?
