So I'm an idiot or something. I pulled and cleaned the carb. I thought I put it together correctly but now when I turn the gas valve on it flows directly out of all the vent tubes. It goes from the tank straight out of the carb.
What did I miss?
check if the floats are stuck if it has floats like on my pwk carb i did that once and it did the exact same thing so my dad just tapped it hard and it was unstuck and worked fine. if that dosent work take it apart and check the floats
i know the exact problem, all you have to do is just take the float needle and turn it around the other way. you must have put it in backwards when u put it back together.
