Clutch Rebuild Pics inside!!
Alright so the bike is a 1999 RM125. The problem is when you are in neutral, pulling in the clutch and shift into 1st gear, the bike stalls and lurches forward.
After Taking off the clutch-cover I see that the plates look ok, although I haven't put the caliper on them so I don't know if the thickness of the plates are in spec but they will be getting changed regardless.
The clutch basket was put in before I bought the bike. Its a hinson basket and that piece is in good shape, no grooving whatsoever. Im thinking the previous owner had the same problem and just assumed it was the basket. The inner clutch hub however is pretty chewed up and the "teeth" feel really rough. You should be able to see this is in the pics. I am wondering if the inner hub would be causing the problem.
Also I have adjusted the clutch cable and it never made any difference at all.
