Okay, for those who are interested, I finished my CR today and got to ride it. Here are my mods:
Vertex piston for Husqvarna 125 (53.94mm)
Cometic high compression gasket set (thinner base gasket)
Power valve spacer
V Force reed cage
Shortened factory silencer (cut down 50mm)
I am running 50/50 mix of 110 octane race gas and 93 octane pump gas. I turned my air screw to 3 turns out with the needle on the second groove.
"SEAT OF THE PANTS" RESULTS
After the heat/cool cycles of break in, I had a chance to ride around my field today. I am happy, not by an amazing power increase, but by the increased width of the powerband. Before, the CR was a midrange only motor. When exiting a turn, you had to clutch, rev and the rear wheel broke loose then try to shift before you ran out of midrange power. Now the power is much easier to control. It comes on sooner and pulls longer. This makes exiting a turn much easier, it pulls out of the turn before is hits peak power, then revs until the next turn. Much more ridable!!
Best of all, these mods are cheap, the only thing I spent that costs more than a routine top end job was the $130 for the V-Force.
Oh, and the motor doesn't rattle any more. Sounds good and tight. This is the way the CR should have came from the factory!!
Thanks Marcus and all the other DRN tuners for the info.
Power valve spacer
V Force reed cage
