slapshot1540
- Jul 27, 2008
- 53
- 0
can anyone just roughly walk me through installing a cylinder sleeve?
what?whenfoxforks-ruled said:If you have the equipment, then you should have the knowledge that replating is a lot better choice than sleeves? Course you could market power now, spark enhancers and unobtainable power bands?
Rich Rohrich said:It's still not a job for a novice. Send it to a professional.
thanks alotOl'89r said:Very true statement. :cool:
But, since you asked and you have the equipment.....
Chuck your cylinder up in your handy dandy home boring bar and bore the cylinder out to a few thousands under the OD of the new sleeve. The sleeve must have an interference fit and the exact figures will be supplied with the new sleeve if you use a LA sleeve.
After the cylinder is bored to the proper size, scribe a line on the side of the sleeve that lines up with the edge of one of the ports. Then scribe a line on the top of the cylinder that also lines up with the same port in the cylinder. This will help to align the ports correctly.
Heat the cylinder and chill the sleeve in a freezer. After the cylinder is heated and the sleeve is chilled, take the sleeve and cylinder over to your 20 ton hydraulic press and line up the lines that you scribed on the cylinder and sleeve and press the sleeve in. Some use red LockTite on the sleeve, some just press it in.
Then take your porting tools and match the ports in the sleeve with the ports in the cylinder. Be sure to bevel the edges of the ports so that the rings don't catch on the sharp edges.
Once the ports are matched, chuck the cylinder up in the boring bar again and bore it to size to fit the piston. Then finish hone it with your hone. Go back with your porting tools and make sure the edges of the ports are beveled being careful not to touch the freshly bored and honed cylinder surface.
That is the procedure for a straight sleeve. Some sleeves have a register on the top to keep them from slipping in the cylinder. If your sleeve has a register or lip, you will have to machine an area in the cylinder to accept the register.
Pretty simple stuff.
All you need is a boring bar, a mill, a press, a hone, porting tools and a little time.
Or you could send it to a pro. ;)
