john3_16 said:I wouldn't consider an electric servo motor opening a powervalve as technically advanced..It's still the same design using a different means to do the same thing...The only difference is you have an electric motor opening a powervalve instead of a totally mechanical process. More of a useless gimmick than a breakthrough in design technology...
Bruce is right. It was considered more technologically advanced because an electronically operated valve can make use of sophisticated computer control. It's hard to achieve that with a mechanical valve, so they essentially operate in a binary/ternary fashion.
In practice this probably helped contribute to the overly-linear power delivery of the CR motor, so technology can certainly be poorly applied..
