Clint3240
61
im gonna be pulling my carb off to to maint, i was wondering if i should pick up any gaskets before i do this.....2000 rm 125
RM_guy
Moderator
7,045
208
North East USA
It's always a good idea to replace paper gaskets or O-rings when you disassemble any joint. The intake track (between the carb and cylinder) is especially critical because a leak can be catastrophic.
tyler_43
126
uhm well are you gonna pull your reeds out? because if you are just pulling your carb off the reed block, popping your gas line off and your throttle slide out to clean it you won't need anything. That is unless the little rubber gasket between the carb and float bowl is screwed but I've never had one leak when I've reused it. Some carbs have paper gaskets there and if this is the case you will need one... but I'm pretty sure a 2000 rm125 has the same carb as mine so I doubt it.
