Supafly_MX
42
Hi there
My local car accessory shop has a special on Semi Synthetic SJ 10W40 car oil (4litres).I wanted to know if this oil would be safe to use in my CR125 ???? Will there be clutch slippage if i use this oil ??
Would'nt this oil be the same as eg Motol 10W40 Semi Synthetic?
Cheers
Supafly_MX
Jasle
1,358
depends on whether or not there are friction modifiers in it. I guess it "might" work just as well as any other oil NOT designed with a bike in mind. If your just trying to save money use ATF and change it often. Otherwise you ought to stick with something designed for the bottom end of a motorcycle in mind. Car engineers werent thinking of wet clutches when designing their fluid. At least ATF engineers were.
sick 96 250
1,207
just switched to ATF type F. Best stuff i have used, especially at $1.49 a quart. I've used gear saver and many others but this is the best for the money and have no clutch problems like i was having before with other oils.
Jasle
1,358
$1.49 a quart. Its $4.88 a gallon at Wally mart. We change oils every 2 motos on our bikes in the summer. At that price you can't not change it.
