I need to order a crankshaft for my sons 1997 kx60 and noticed while looking up the part # at www.buykawasaki.com that the 99 and newer kx60 has a different part # .
The diagram shows the newer crank having a different rod ,bearing and shims. Does the newer crank help eliminate the rod bearing failures? And if it does will it fit into my 97? the crank halves still have the same number as the 98 and older cranks so I don't see why it wouldn't fit.
