HELP NEEDED with KDX
Just got my son a 1984 kdx 200, it's running terrible when first starts it seems o.k. after riding for about 10 minutes it starts to bog real bad I think I could run faster than the bike and will stall. It was running rich when we got it, so we did variuos like clean the air filter, change the gas , plug, and moved the clip up one. started much easier in 3-4 kicks with choke on. But stil runs like shyt soon after. It seems to still run rich by looking at the plug it is a very dark brown & a little wet. Moving the air adjustment seemed to do no good either way all the way in to all the way out. The clip is currently in the second from top position, wondering if I should attemp to go to the top? The guy we got it from said he just put in boysen reeds but didn,t make any adjustments. although I have since we got it. Just trying to figure this one out. I thinks it's when it gets hot it bogs, or a rich problem. I've seen alot of talk on here about Adjusting the main and the pilot. not sure what you guys are talking about, wondering if they atre adjustments I should be making to try and correct my problem. It's all new to me I'm a 4 stroke guy. But with KDX I better learn the 2's.
