bmoore4w21
- May 2, 2005
- 12
- 0
So the story goes that I was finishing the last 25 feet of some of the worst terrain I've seen and I thought that I would just blow through this puddle at the exit of the trail. Little did I no that it ended up being 3 and 1/2 to 4 feet deep. My KX 250 was not happy with me.
Anyways I got it home without running it at all. I removed the cap that sits on the head. I sprayed down the piston and cylinder with WD-40 to prevent rust. In addition I removed the exhaust, air filter, and the oil in the crankcase. Im not an expert but I'm pretty confident that I did the right thing to avoid any major damage. My problem is that I can not start the bike now. It appears that fuel is not entering the cylinder. I layed the bike on its side to remove any possible water in the carb. however that did not work. Is there something I'm missing? My only last idea is to remove the carb. and examine it. Possibly disassemble and the reassemble. But I thought I would ask the experts out there for there advice first. I couldn't be the first to do this! FYI the bike is a KX 250 '01. Thanks for the help!
Brad
Brad
