mprest4
90
i will be racing my 95kdx 200 this sunday on a 70's style mx track. only one table top and not enough whoops that they matter. it is basically turn after turn with gradual elevation changes. the track will most likely be very soft to muddy and it will probably rain.
i can't change out springs or set my sag before the race but i can adjust the clickers and set the tire pressure. what would you guys recommend for these type of conditions.
i am going to drop tire pressure to about 8lbs and stiffen compression on front forks. reduce rebound on rear. does that make sense? i'm new to racing
Robcolo
342
If you can't / don't set the sag - or at least measure it and see if it's in the ballpark -- there's really little sense doing any of the other stuff
