My tire is getting rounded off pretty good, a little too much on the road I guess, but it's too tough to avoid. Anyway, a friend of mine said you should just reseat the tire the other way around, so the sharp lip of the tread would be biting the dirt, but I wasn't sure if that would work right, since the tire might not be made for that. Also, for a dirtbike do you need to have the tire beads broken with a tool and then resealed the same way, or can you do it like a bicycle by just deflating the tire to get it off and inflating to get it back on. But is it a good idea to get some more life out of the tire to swap it around.
