How do you install these crazy things. I thought i knew how it was done but afterwords i wind up pulling the whole bunch (3) off at once or simply couldn't find the tab. :bang:
I could show you better than I can tell you, but here goes:
make sure lens is clean
install first tear off on lens pegs
roll big hole in tab over onto peg
install next tear off on pegs, holding big tab down
repeat steps 3 and 4
Sometimes the tabs won't pop out, but it seems to work relatively well. There are also laminated pre-packed tear off setups that I guess work well.
Of course, I use roll-offs, so . . .
also, your thread title reminds me of a story: A pirate walks into a bar. He has a steering wheel attached to the front of his pants. Bartender asks "what's with the steering wheel?" Pirate answers: "Arrrr! It's drivin' me nuts!"
To make finding that tab a little easier, try creasing the folds when you are finished, it will cause them to stand off just a little farther from the strap.
Depending on when brand of goggles you have they may offer laminated tear offs (were 7 tear offs are stuck together so dust doesn't get between them) but then you just have to worry about the loops on the pull tabs so you don't grab the bottom one. You just need to find the style that works for your riding. You may try the roll off system too if you can't get it worked out. Good luck and happy riding!
