YZ-250F 2003 Blown Cylinder Head
Roma
11
I was riding the other day and my bike started to sputter on the top end. I thought there might be a leak in the intake boot but that was not the case. The next thing I knew the bike stopped after landing from a jump. I pulled off the Cylinder Head and it is badly damaged. Two of the valves broke off. I never adjusted the valves once nor did I on my 01. I guess I figured when it became hard to start it would be time. It started on the first kick that day. Now I have some questions. Where can I find a cylinder head cheap? Rebuilt? Who has the best deals on them? Can it be repaired? It looks like it's dinged up pretty good. I still like Yamaha's even though this happened. Any advice appreciated.
Roma
11
My local dealer said the crank bearing might have started to loosen up and caused the piston to hit the valves. I thought only the 01 had crank issues
It's possible that the main bearings are worn, but they would have to be really worn to allow that degree of piston movement.
I'll bet your statement above is probably why it broke a valve.
You can't ignore the service intervals indefintely without paying for it at some point.
It's a 13,500 rpm RACE ENGINE, it's not a John Deere garden tractor.
Roma
11
I got spoiled by by 01 but only kept it a year and 1/2. I was hoping to make it until the 07 came out. Now I'm paying the price.
Does anyone repair cylinder heads or sell used ones?
You can check with Eric Gorr and see if he has any refurbished heads left in stock ericgorr @ hotmail.com
