My 98 YZ250 was working fine until this afternoon, I noticed a hard shift between 2nd and 3rd then I thought I heard a grinding noise. Took the bike into the pits and all seemed fine with a visual inspection. When I returned to the track I found that the bike would no longer shift from 2nd. Finally when I got it down to 1st thats where it stayed. The shift lever does not move properly. Clutch does not disengage properly when the bike is not running.
My suspisions are that either a clutch piece has broken off and jammed in the shifter drum or a bent shift fork/shaft. I will be taking this apart real soon to take a closer look. Does anyone have any suggestions as to what the problem may be? Or perhaps which of these suspected faults may be more likely.
