jeb
- Jul 21, 1999
- 633
- 0
Well, I had one of those weekends. I was at a trailride in Northern MN. All arrowed and mapped trails. Lots and lots of fun stuff with probably 60+ miles of trails. It was hot but I've been jogging in the heat so it didn't bother me.
Yesterday, on a loop that I was taking it particularly easy on I was following a buddy in the single track. He's not as quick in the woods so it was an easy pace to keep. About 1/2 mile into that single track I heard something in the engine. So I cock my head and listen real hard for a couple hundred yards and then it suddenly started knocking LOUD. Shut it off immediately. The 3rd of our group rolled up behind and asked if something was wrong.
The engine was leaking a little antifreeze out of that weep hole under the water pump again so I thought maybe I'd blown the seal and lost the antifreeze again. Loosened the cap a bit and AF came out. Once the pressure was gone, I took the cap off and it was full. Let it cool off a bit and started it. Knocking badly. Shut if off. There was really nothing to do for it. I decided to turn around and go backwards to camp as I knew that was only a couple miles. My buddy was going to follow me to the ATV trail and then go chase the first guy down and, I thought, come check on me.
I went about 200 yards and decided it was making too much noise. Plus, AF was RUNNING out of the weep hole now. So I shut it off and started pushing. Good thing it's so flat up there. I figured I'd have my buddy tow me back with a rope I carry but he never showed. I assumed we had mis-communicated but it turns out it took him 15 minutes to get his WR250F started. By the time he got to the ATV trail, I'd pushed it beyond that point so he went to find the other guy thinking I'd ridden it out.
Now, imagine my little private hell here. It's hot (95f), it's humid, it's
sunny, I'm totally depressed and I'm pushing the most fun bike I've ever owned out of the woods. It was just rolling terrain with some sandy whoops for variety. I thought pushing it up slope through the whoops would be the worst but it turns out the long flat sections in the sun were the bad spots. If I stopped and rested, it was worse. The heat would just make me drip like a wet dog. So on and on I pushed. Of course, nobody ever came by during the whole deal. I figured I pushed for about 1.5 - 2 miles. The last piece on a gravel road sucked because it's a long up slope back to camp. My buddies showed up about 1.5 hours after I got back. They rode out the entire fun loop instead of taking the shortcuts back.
I'm pretty sure something happened to my camshaft. It's the only thing that makes sense. The waterpump seal and impeller are right on the end of the camshaft so for it to start leaking without having overheated it only makes sense that the problem lies there. I trace this back to my having overheated the bike badly GPSing at our clubs trail this spring.
Details on that incident. I was still getting used to the bike and I'd never had it overheat. I'd replaced the hose clamps on the stat like a good boy before I ever rode the bike. So we're working through the trail and getting around a lot of blow downs and 'whoosh', it steams and overheats. I wasn't happy about it but thought it was just hot. I rode for a while like that until I heard some knocking. Shut it off to find the bottom clamp had blown off the stat anyway! I fixed it on the trail and my camelbak exactly filled the bike. It ran fine after that.
It seemed like I had more engine noise after that incident, though, so I've really been a little suspicious ever since. Plus, no one else seems to have had this problem. The RFS's seem pretty bullet proof from everything I've read.
My 99 250EXC used to boil an ounce or two on a hard ride and it dumped it on the pipe so I didn't give the steam bath the import I should have. Moral of the story is if your RFS boils/steams and you've been following the don't let it idle for more than a minute rule, shut it down and look at those hose clamps. There's apparently a lot of pressure in the line coming into the bottom of the stat housing.
I'll have to tear it down to even begin to diagnose it. I'm hoping for camshaft bearings but fearful it will involve replacing heads and cams. Any advice gladly taken.
