Hey guys. I was working on my CR trying to get the flat spot out of it and I took the carb off the ensure it is clean and all that.. It was. I checked the float and in the manual it said to measure it at 15mm over the main (high point) and to adjust with the float lip just touching the float valve. So I held the float just touching and adjusted accordingly. Upon reinstall and turning the gas on it overflowed. So I went back and adjusted it to 17mm. This is about half way between where it was and the 15mm. It didnt overflow and one bonus is that it was surging at idle and isnt anymore. The way the instructions in the book are written are not clear to me and confusing.. Any help is appriciated.
Is some other posts I have been working on a lean spot on the low end and I am now leaning toward the pilot starving. I hope this simple fix is the problem. If so it will be a great ride at paragon this weekend.
