Hey everyone. I need some help from the experts. I got an 01 CR125 over the winter. I have been riding a bit at Paragon (see you all next weekend :laugh: ) and continue to have issues with my bike. When under load at the lower end of the rpm range (very slow techincal or when you hit a puddle and it is actually a small lake) and you lay on the gas it just totally boggs. A little clutch gets it going but sometimes it is really tough to deal with. Have crashed a few times going real slow. I do well with jetting and have checked the plug. Looks just a touch rich. Dry and on the darker side of brown. I have tried many combinations to resolve. The following is my set up that almost eliminates the issue but it is still there and always crops up when I really dont need it to. I have tried leaner settings and it gets worse. I know it is a touch rich as the pipe is wet. Not horrible but dripping down about 3" from the spout. I do not motocross and only trail ride.
Temp 80 deg. 60%humidity
C-12 at 40:1 Belray Syn.
Stock Pipe with FMF Turbine Core Q (same result with Bills Pipe. Went back to stock to help figure things out.)
Boysen Power reeds in stock cage
360 main
Stock T0 nozzle
69 needle on 3rd clip
40 pilot
2 turns on air screw
I am drawing the concusion that the Power Reeds are not the right choice. Are they just for RAD valves? While I totally understand that a 2 stroke has no low end, and the 01 CR being one of the worst, I am really just looking for responce with no flat spots.
Any and all Suggestions are GREATLY appriciated. Will purchase anything suggested.
360 main
Stock T0 nozzle
40 pilot
