The 02 definitely needs more top end. I find myself shifting a lot on long straight a ways in comparison to my 01 cr. I am waiting for someone to try out the motosari reed cage or porting to see if that helps the top end.
02 turns better than my 01 and the suspension is great; it is firm without midstroke harshness, I had to turn the clickers out on choppy tracks( I will most likely put the ss7 oil in when I change the fork oil in the future since that made my 01 forks even better it should make the 02 forks better as well. The stock jetting is fine.
I do not think that the frame feels less compliant than my 01, it still has a very solid feel, but the suspension is much better. Enginewise, you need to shift a lot due to less over rev than the 01.
