I've logged about 100 miles on this bike now. no mx, all off road. Intend to do some hare scrambles and enduros once set up. The riding in central Florida is a lot of roots, logs and a lot of large high speed sand whoops. The roots are beating me to death. I put the shock high speed damping at 1 1/2 turns, lowspeed comp. all the way soft. Yesterday I put the stock straight spring from my 98 200 mxc on the shock. (Its 10mm shorter but as I weigh 160 lbs I was able to get the sag right) and it worked MUCH better (believe it is rated at 76 k/mm, but can't read the stamp anymore). When I put on the straight rate spring (progressive spring is rated 71 to 91 k/mm) I added 2 clicks low spd. comp damping. Also have comp. on forks turned almost all the way soft and they are still too stiff for roots. My question is am I going in the right direction with lighter springs for my type of riding? Is a straight rate shock spring the way to go? I will probably be sending my stuff to Jeremy for a revalve but would like to ride with softer springs first if this is the right guess.
I haven't messed with the oil level and weight yet as I don't have the spanner needed to remove the 48mm fork caps. any ideas? thx.
