Hello all. Will an 02 KX250 (19")wheel assembly (rim/brake/hub) mount and work on my 01 KDX220 with stock 18" wheel? Will it require different wheel spacers? Has anyone tried this? I need to replace my rear rim, and this seems like the easiest fix if it will work. If it works, will I need to change my rear sprocket size to compensate for the larger rim/tire?
Thanks a bunch.
Thanks a bunch.
