robwbright
2,283
Hi guys:
I recently purchased an 02 RM 125 with title.
However, serial number is not visible anywhere. Anyway I can verify the S/N by cross reference with the number on the engine?
Rob
High Lord Gomer
Poked with Sticks
Sep 26, 1999
11,788
35
On most bikes it is on the steering stem. If you turn the bars all the way and then look at the steering stem from both sides you should see it.
robwbright
2,283
I know where the s/s is supposed to be, but its not there. There is a number on the engine.
I guess my question is . . .
Are the engine s/n and the frame s/n identical when the bike is stock?
ChopperDave
It's been awhile...
1,091
The engine number and frame number should be different. Maybe a trip w/bike to a local dealer could settle it for you.
a454elk
Mexicutioner
7,529
18
You have to cross the engine number to the frame number. Although, unless the bike came from the factory race team, there should be a number on the headstock. If there isn't, you may want to have to checked out as soon as possible because when you go to register it in your name, you may have some questions to answer about it. See if it's obvious that the number is taken off or the area is perfect an not touched. If you got a title or MSO, it should have the number on it as well. If you bought it without papers then that's something else. Good luck
FRESH VIDEO
