I just bought this bike and there was no oil leak. I tried several times trying to start this thing not knowing there was a decompression lever. Could this be the cause of the oil leak? Suggestions would be helpful?
I would clean it off very well and try to pinpoint the source. Starting without using the decomp lever whouldn't cause an oil leak. A broken kickstarter and a sore foot, maybe.
Did you ever get it started? If you get stuck, there is an excellent mechanic not too far from you in Woodstock.
I can get it started. I even got it started without the decompression lever. Do you think it could be a seal. It seemed to leak more oil in the cold weather. Who is the mechanic. THanks for the info and help.
