frequentflyer
- Sep 6, 2005
- 1
- 0
purchased an 03 kx125 for my son last week. the bike ran great when we tested it out. took it to the track this weekend and it started making a knocking noise in tranny. sound is coming from area possibly just inside countersprocket area. when the bike is in neutral and you turn the back tire you can hear the knock with every revolution of the countersprocket. it will not make the noise when you turn the tire in the reverse direction. its like the bike is trying to shift in to first gear. if you crank the bike in neutral while on the bike stand the knocking is a louder and the bike will jump into first gear. while my son was riding the bike you could here the noise clearly in first and second gear. sounded like a chain rattling real bad but it wasn't. third thru sixth gear was fine, no noise at all so just kept out of first and second while riding.
also it sort of comes and goes. occasionally it would not make the sound. now here is whats funny. if you turn the rear tire while the bike is on the stand and in neutral and then pull in the clutch the rear tire will stop like it is in gear. now to make things worse i don't have a manual. i did check the clutch all the way down to the clutch basket and every thing looked great. however i had to adjust the clutch several times yesterday. ok just went out to garage to make sure i didn't miss anything and found the tire is turning while on the stand in neutral but when i take it off the stand the bike will not move as feels like it is in gear. i hope this makes sense to someone. if anyone has any ideas at all please let me know. OH ! the previous owner ran 80 wt gear saver and i changed to 10w40.( maybe the thick oil he was using was covering up something) THANKS
