I have an 04 HONDA CR250R with an RC valve that intermittantly when you go to accelerate does not open. I have cleaned and ajusted the valve. I have replaced the actuator. I have replaced the ECM. I have replaced the voltage regulator. Nothing has made any difference. It is hard to diagnose becouse it is very intermittant, but I have wired a test light into the actuator a couple different ways and taped to the cross bar pad. The ECM reverses the power and ground to the actuator to close it as well as open it and it apears as though when the valve does not open that the ECM is actually trying to pull it in the closed direction instead of open. :bang: Just hoping someone has seen this or has some idea what could cause it.
