Cr85RaCeR607
191
Does anyone have experience with a 144 kit on an 05'-06' Cr125. I want to know how they respond to the 144, and how they compare to the other models with 144s in them too.
MXP1MP
1,845
No so far all I have done is just ridden a stock one at most that had an FMF fatty pipe I bet it would haul if done though, since it worked great on the older motors and the newer style motor generally seems to run stronger/better.
robwbright
2,283
While I know nothing about the 05 CR125, I have yet to hear a bad report on an Eric Gorr 144 kit. Virtually everyone has said they're worth the money (including me)! Don't think you can go wrong.
NO HAND
1,198
I believe the cr125 motor 2000 and up can only be bored to 133 because of the cylinder wall being too thin on the exhaust side just above the power-valve.
MXP1MP
1,845
No that is correct it can only be bored to 133 the motor is then stroked to get the rest of those cc's. They just add alittle bit to the crank arm length.
Cr85RaCeR607
191
So then what would the cost be to bore a CR125 out to a 144. It says $450 on the front page of his site, $475 on another page, and then on the front page it says "price Increase"...So what is the price. Also, since the CR has to be stroked, is that more $ added on top of that cost?
MXP1MP
1,845
It was $475 for the big bore's the price is going up effective 01/01/06 how much I don't know exactly but it won't be no $475 anymore. Plus the cost of the crank rebuild so that might be another $300. It's a bit of a minus with the CR's engine but on a 125 I don't know if 8-10 cc's is going to matter that much really in actual overral power. Now give me a few more weeks and i'll let ya know what my '06 YZ 144 is like :)
robwbright
2,283
Actually mine was $450. From what I've read, the 134 kits make almost as much peak hp as the 144, but its higher up in the powerband. The 144 is more or less for for midrange improvement and the 134 for mid-top.
However, my mid and top are both MUCH better than stock.
MXP1MP
1,845
So I've heard the 133 is suppose to be the better setup for some who spends alot of time in the upper rev range in lower gears. How was your 144 ported? mine is going to be ported for more mid/top. I was going to just mo' betta but heard it was mainly for midrange and took away some of that mid hit.
Pete Payne
MX-Tech Suspension Agent
Nov 3, 2000
933
38
Yes you can overbore the cr 125 to 144 cc . I have only done a handfull of them . ( 3 ) also did a 3mm over for Steve125 . Maybe he can chim in on it . To 1444 the cr it is tricky you have 2 problems to overcome . 1 - the exhaust port becomes huge if you just bore straight down locating off of the original cyl bore . and 2 - the rear exhaust studd it pretty close to the cylinder bore .
Yes you can also make them rev realy good and make peak HP at 11,000 -11,500 . reliabilty is not an issue when using Eric's pistons.
Cr85RaCeR607
191
Pete, so you are saying no crank stroking is needed? Also, my 1st question, how does the CR with the 144 kit compare to the other bikes with 144s. I know that they are a little down on power as a 125, but when it has the 144, would it be the same as any other brand with a 144?
MXP1MP
1,845
That's what he's sayin I like to hear that cause my friend has an '06 CR 125 who really wanted to make it a 144 by just boring it alone but was going to throw down an stroke it also. The $$$ isn't the issue just wasn't real thrilled with having to stroke it he really wanted to make it more of a 150 by stroking it. If EG doesn't do this service when he's ready I'll have to get a hold you pete then! Right now it's the 500AF getting rebuilt so could be awhile.
jmossbarger
68
Wiseco will have a 57mm CR125 piston on the shelf in about a month. I spoke to Eric this morning and he said he usually just does the 56mm. 58mm pistons will be available as Wiseco shelf parts for the RM (the RM piston also fits the KTM) and the YZ.
Joe
robwbright
2,283
Joe
Ye, but Eric's 58mm is better and cheaper! :aj:
After all, he designed WISECO's big bore pistons (the ones prior to 2006). They're going their own direction now, apparently.
Pete Payne
Nov 3, 2000
933
38
The whole trick is to offset the cylinder bore . No stroking needed . The problem with the cr is the exhaust port gets to be huge when the 58mm (144) bore is located off of the stock bore .
