Got to agree with Joe, clearance and timing. Be glad you do not have 2 cams up top! And sadly, how well was the valve job done? If the clearances check out, you may need a leak down test to see how your top end is sealing up. Vintage Bobblanc said:bike is just as hard to start when warm. will re check valves and timing thiseve. cant understand it
The mixture screw! No star for you today. But, yes it can make starting a real bugger? NOPE. The leak jet, choke circuit and probably technique are the biggest factor on starting, as long as its not something else. The thumpers since 05, tuned and it good shape, I've personally never needed the choke or hot start to fire up. 2 blips of the throttle and bam, worked almost every time. Except frozen or freshly crashed, then its another story. It started fine the normal method, but was cooler, less work. Vintage Bobbrad m said:You can also check your air screw adjustment. Should be around 2.5 turns out.
Yeah, Bob, this ain't yer 'ol two smoker. :nener: As far as I know there's no adjustment on the pick up. It's also oil bathed so corrosion shouldn't be the problem. Particles could end up getting stuck to the terminals I guess. Hopefully not because that means you've got much bigger fish to fry. Go pick up a gasket and pull the cover. It's pretty simple and will allow you to look for any shavings in the ignition or sump screen as well as giving you an opportunity to check for bearing play. I just bought a side cover gasket and I think it was around 10 bucks.whenfoxforks-ruled said:Plug cap, lead wire, then the coil, and the 8 dollar kill switch, cheap. CDI box, stator, expensive. And, the pick up on the side of the rotor, can get whacked out of adjustment, or worse, all corroded up. Keep at it. Vintage Bob
