I need more low end for my 240 lbs in the tight and steep moutain single track I ride here in Utah at times. Should I just put a 12 tooth front sprocket on and keep the 47 tooth rear or should I go with the stock 13 tooth up front and a 50 in the rear? I found where it was advised to change to a 12 tooth up front for more low end but then recommended going with the 13x50 if you were replacing a chain. What is the advantage?
It seems to me that it is easier just to change front spockets depending on riding conditions.
Thanks in advance for your input!
