Ok, I finally have a spark on my vintage DT1. Can anyone suggest a way to set the timing? The bike has no battery. All the electrics are removed except the black wire off the alternor that runs to the coil. The other leads still come off the generator, but only the black is connected to anything. The only time there is juice is when I kick it. With no juice in the system, how can I tell when the points are opening so I can set the timing? Can I attach a battery to one of the other leads to power up the system long enough to check it? Surely someone has faced this before. Any help would be appreciated.
