1994 RMX Dogbone Bearing
I need to replace the dogbone bearing where the shock connects. Can I get this at a bearing shop or do I have to go to Suzuki ($$$). Also, do you know the bearing spec's.
Brian
Take it with you to the bearing house. It should have pertinent numbers tamped on the side for the counter worker to match it up.
How's the (purple) shock spring working out?
Purple Spring
Placelast - the spring is GREAT. The front end is much more stable, and the rear hooks up much better. Traction on hills seems much better also. I guess the rear end doesn't squat when climbing anymore. I can actually steer while climbing - what a concept. Thanks again.
Brian
P.S. - I never heard back from you to find out if you got the spring and money order.
