Jul 15, 2007
69
Anyone? I unscrewed the lock screw on the top of the rear spring. I was told to turn the spring but theres no where for it to go. Someone please help.
IndyMX
Crash Test Dummy
5,548
Amo, IN
Do a search, there are many other threads about this subject.
After you loosen the top lock ring, you either tighten or loosen the bottom lock ring to get the sag you are looking for.
But, if you don't know what or how to measure, it won't be right anyhow.
Jul 15, 2007
69
So there are two rings? I know how to measure the sag. Measure on stand, then measure weight bearing and it should be 100-105 mm less.....ok thanks, the second ring must be a lot tougher to move.
IndyMX
Crash Test Dummy
5,548
Amo, IN
Measure on the stand, then off the stand without your weight.. That's static sag.. should be about 25 mm... then measure with you on it.. 100 mm or so..
Second ring is a tough one.
