insutama
42
First, I am gonna have to replace the clutch cable on my 02 yz 125 and i was looking at were it goes and im thinking im gonna have to take my pipe off to connect the cable to the clutch dose anyone have any advice also on how to set up the clutch when i replace the cable i was just gonna trial and error it till the clutch felt right.
Second question. I wanna drain all my coolant out of my rad and flush it then replace it all i just cant seem to find a drain on the bottom of the RAD dose anyone know were abouts it would be ?
thanks in advance for any help
Backslayer
Go Big or Go Home
280
GET A SERVICE MANUAL. on your cable there are plenty of adjustment to loosen or tighten the cable you want 3/8 of freeplay meaning when you pull your lever it should start pulling on cable till about 3/8, second there's no drain on your radiator its on your water pump cover youll see a small bolt usually they have a phillips head in there with a brass washer pull that out to drain.
