2001 cr 125 back to stock settings
i have a 2001 cr 125 that my older boy rode and moved onto a 05 crf250 then a 07. so the 125 been sitting in my garage for a while now. My younger boy has growen big enough to start to ride around on the 125 but i need to adjust the suspention from were it was for my older boy he. He was about 205lbs and had everything set pretty stiff. My younger boy is 105 lbs now so i need a basic idea were to set the clickers for him..the sag will be set up for him i just need the rest.
Suspension Settings
Set the sag at 100mm or 4 inches and then for Outdoor MX
Forks
Compression:14 out
Rebound:12 out
Shock:
Lo Speed Compression: 13-14 out
Hi Speed Compression: All the way soft or 1/4-3/4 turn stiffer
ReBound:12 out
Arenacross/Supercross
Forks
Compression:12 out
Rebound:10 out
Shock
Lo Speed Compression: 12 out
Hi Speed Compression: 3/4 turn from Full Soft
Rebound: 10 out
This should get you in the ball park. Not exact. You should probably get softer springs if he's that young and light.
what do you mean by 14 out? how do you tell what number it is? i dont have my dirtbike here right now so for all i know the numbers could be right on there, if they are sorry. i have never messed with my clickers only my sag.
